1986 GN. Approx 100000 miles. $13,000
Go here, 2nd car from the bottom.
http://www.usol.com/~maxfrt1/customers.htm
Not perfect but not bad. I have owned this car from day 1. Drove it out of the plant. Full roll cage professionally installed with swing out bars.
Boxed rear arms with poly bushings.
Alum brake drums.
Double pumper.
Aluminum drive shaft.
Rich Cook built 200R4 with extra clutches.
9" Art Carr
Scanmaster and digital tach with EGT.
Staked ported heads.
Fairily new .030 stock pistons.
Staked fully ported heads.
Girdle that leaks a bit, not sure where.
DeQuick stretch.
Wheelwell dump.
Fresh TE-63 with good thrust bearing.
New never used $560 Mease 3.5" stainless downpipe with stock type wastegate, un-installed.
New in crate fiberglass hood with a roughed up corner from what I see, looks like an easy fix.
New in box fiberglass front bumper.
Extra 8.5" rearend
1 run on the motor, needs heads re-torqued. 2 or 3000 miles of street use without getting into the boost.
ECM modded with drivers and MAP input.
62mm TB
Accufab upper manifold.
Bell stainless headers...look real good.
Dual deltagates.
Car is completely driveable, will get 19-20 mpg on hwy. Is more leaned toward race than street as far as appearance.
Complete automatic climate control heater/AC assembly intact and un-installed.
AC compressor un-installed and uses a idler pully in place of it.
AC compressor needs rebuild.
ME-R with 75 pound Delphi's.
8" ARE's in the rear with BFG 275-50-15 drag radials. 7" ARE's up front.
Also, 8" ARE's with 28 x 10 slicks mounted. Mickey Thompson.
Will not seperate items at this time.
Will not ship anything, must pick up...... Michigan
Also for $5000, older 3.8 stage 2 dyno short block . Never in a car from what I understand. This was destined for car above.
Comes with New, 3yr old un-installed bone stock Champion 14 bolt heads and new T&D's
Not R heads, these have approx 1 7/8 intake valves. The generation of Champions just previos the the presant.
Flat top 10 to 1 pistons, maybe higher than 10 to 1.
Has Oliver rods from what I understand.
Has Steel crank
Stage 2 iron heads that came off from it.
Stage 2 carb intake.
Will not seperate these items concerning the stage 2 either.
$17,500 for all.
I don't want to sell this stuff but it looks as if I have to. Retiring on short notice plus other issues.
Steve Y.
Best to email if interested. maxfrt1@usol.com
I can call when we set up a time.
Thanx.
Alum brake drums.
Double pumper.
9" Art Carr
DeQuick stretch.
Wheelwell dump.
Extra 8.5" rearend
62mm TB
Dual deltagates.
Has Steel crank
$17,500 for all.
Steve Y.
Thanx.
