GNbythebay
- Jul 28, 2016
I have a 1986 GN while under around 5-10 psi it makes a popping noise(My boost controller is set at 15 psi). I Heard this could be because of an old coil pack/spark plugs and wires but i  just changed the spark plugs wires and coil pack. (I bought a ignition module too but cant find the location to install it ). What could be causing this? I also just installed the fuel pump and hot wire kit with 42lbs injectors with the tt chip and a fuel pressure regulator.
