Up for auction is my 86 Grand National. I have had this car for about 9 months. I love this car and really dont want to sell it but I want t. I have put alot of time and some money into this car. The interior is a 9 out of 10 ano get e new truck The exterior is prob a 7 because it needs some body work and a paint job. Asking 7400 OBO. As follows is everything that has been replaced and is good and everything that is bad
79600 miles
Schnider cam installed card is in car.
Turbo Tweak chip
#36 injectors
K&N filter
VDO gauges (Oil pressure not hooked up but have the line to hook it up, Volt gauge,Temp,Vac/Boost,Caspers knock gauge All installed and working besides oil pressure.)
Kick pods with 6 1/2 Diamond audio speakers
Kicker 6x9 component speakers installed
Clarion flip out dvd/cd player touch screen
New top dash
New passanger window motor
New windshield wiper motor
New front bumper fillers
New window felts
New Ignition control module
New hood spring
New grille springs
New hood shocks
Nice American Racing polished 15x7 torq lites the fronts are BF Goodrich 215/65 and the rears are Mickey Thompson 255/60 ET Streets front and back have about 85% tread left.
Reds hot wire kit
Art Carr stall converter
Shift kit ( dont know which one)
2 1/2 duel exhaust
power seat functions work, power locks work,mirror adjusters work, heat works
sway bars have been upgraded
Shocks have also been up graded
Digital dash upgraded to go 199
Drilled and slotted front rotors
Headliner was replaced
The motor was rebuilt in 12/8/2008 thats also when the cam went in
Have recipte for the art carr install and also the motor build
The Bad
Needs some patch work and paint job. It looks like the paint came off on parts of the roof and right fender. The previous owner sanded it down to the primer and also put POR15 on the rust parts. Theres rust bubbles on the front and rear of the drivers door 3 small rust bubbles about as big as a quarter maybe on the drivers rear fender there is a rust bubble on the passengers rear fender and what looks like the car rubbed up against something and peeled the paint of but was filled in with por15 on rear passenger fender. Missing drivers rear fender molding. There is a dent on the front part of the passengers door. The front header panel must have been replaced do to it has the emblem holder filled in. Left air dam is cracked. Power antenna doesnt work but I have a stationary replacement antenna that will go with it also the rear bumper support is rusted but have a nice aluminum one that will go with it. Ac needs a new shrader valve and a recharge. Rear window needs to be re sealed it has a leak in the corner when you wash it . rear window has sticky stuff still on it from the tint being removed by the previous owner and also the deefrost doesnt work because he cut some of the lines on the window, blower motor doesnt work on high but have the resister to fix it. Cruise control doesnt work prob needs to be adjusted by the gas pedal. The back seat back cushion cover needs to be replaced has some rips in it Passenger side high beam light keeps getting water in it. Rear bumber fillers will have to be replaced.
If this thing had the body work done and a nice paint job it would look brand new again. Trying to buy a new truck so thats why im selling it. I would drive this car anywhere and any distance. If you have any Questions or need more pictures just email me. I have been 100% truthfull about everything about the car. Odmeter reading will change due to driving it here and there. You can PM me Email me or text to 7573190950
79600 miles
Turbo Tweak chip
#36 injectors
K&N filter
New top dash
New window felts
New hood spring
New grille springs
New hood shocks
Reds hot wire kit
2 1/2 duel exhaust
The Bad
