86 Regal project with alot of NEW parts.
buicksstage1
FORSALE: Project roller, 1986 Black exterior/Burgundy(Maroon) interior Regal….Body straight but does have it’s share of those “parking lot scratches and minor dings”. Paint is somewhat oxidized here and there (a good wet-sanding should clean it right up and bring back the shine) and the clear coat is lifting in a few spots on the hood only. That was not a problem for me in that I was going to go with a fiberglass hood anyway. A buddy of mine, well his step-kids, were playing around it and somehow the driver’s side of the windshield next to the a-pillar is cracked from something hitting it so it will need to be replaced, of course "NO ONE" did it as I'm sure we've all heard kids say that. Has the half/vinyl top, it has a split at the very top forward center point. Car is in the middle it’s transformation to a light & fast but streetable car. Interior in excellent condition but does need headliner. The plush original 60/40 split bench in very good condition too. A Custom-Built Dash by Performance Instruments (cost OVER $1500 !) using AutoMeter UltraLite gauges designed by me (pic’s posted below). Car has A/C and new heater core but tracked down (2) different original GM A/C delete “kits”, even has ALL hardware and ductwork including correct dash control AND the correct glove box in the original Burgundy (Maroon) color!! There’s a good 40lbs or so loss right there from what I‘ve read. Other weight loss items include aluminum bumper mounting brackets (replaces 5-mph “energy absorbers“, but also have NOS those too). A rare and hard to find original GM aluminum core support (not installed yet). Aluminum front bumper reinforcement, not installed instead the Canadian Only individuals are. (2) 84-85 front original GM GN air-dam spoilers. Original GM GN 5-piece rear spoiler (NOT a cheap fiberglass repo!). I drilled out the spot welds in spare tire housing and replaced with a rolled and broke piece of 16 gauge so that it looks factory and opens up all kinds of room under trunk. A 20gal w/GM sending unit aluminum cell in trunk with dual -10AN outlets.
Rearend is another braced and black powder coated Moser 9” without the third member so it is the housing and 35 spline axles only. Moser all new rear brake set-up, drums cryo’d and powdercoated black. Kirban driveshaft safety loop. TOTAL COMPLETE HR PartsNStuff rear suspension incuding DBL ADJ uppers w/HD Delrin bushings, (2) pairs of Lowers w/HD Delrin (also a pair of extra ¼“ longer too to better center the rear tires in the wheel well!). HR’s Super Sway Bar, welded HR’s frame braces. Hotchkis frame braces tying upper frame mounts to the lower frame mounts. (2) different pair of the American Racing Vector “T-Type look-a-like” rims, 15 X 8.5”. One pair has nothing mounted on them and second pair has new (stickers) Hoosier Pro Street 29.5X12.5X15 Radials. They fit with NO frame notching but (Also included is a complete custom kit to do so though!) and NO fender rolling! Front rims are original Buick T-Type 15X7 with Hoosier Pro Street fronts. Front suspension is Global West Drag Tubular Uppers and Lowers w/Delrin bushings and AFCO "Low Friction" Ball Joints. QA-1 Coil-overs. (2) pair of slotted and drilled Summit Racing cryo’d rotors. SSBC “Quick Change” aluminum calipers w/pads. Russell braided brake hoses front and rear set. All steering components replaced with Moog components except box itself (There‘s WAY OVER $10,000 in just the rearend, front and rear suspension and braking system including wheels and tires!). Guys...There is NO reason why this Regal with the right kind of finishing work, weight removed in all the right spots and good tuning can not be a 9 second fully-streetable car!
New Unused Stuff
NOS Power Antenna from Kirban
Pair of NOS GM, Delco Front Bumper “Energy Absorbers”
GM lightweight aluminum front bumper support
(4) NOS “T-Type” Center Caps w/ (2) custom made rear adapters for the American Racing “Vector” T-Type “look-a-like rims
Kirban Rear Sear Frame Brace kit
Kirban Front Frame Brace kit
Kirban Driveshaft Safety Loop (already on car)
Kirban All New Body Bushings incl. “GNX bushings” (already on car)
Prothane Urethane Body Bushing Kit (complete incl. “GNX bushings“) (7-132-BL)
(2) Pair of Summit Racing Drilled and Slotted Front Rotors (Cryo‘d), (1) pair on car
SSBC Front “Quick Change” Aluminum Caliper (w/HP brake pads) Kit (A181)
Global West Tubular Upper Control Arms (TLC-88) (already on car)
Global West Tubular Lower Control Arms (TLC-TLC-88H) (already on car)
AFCO “Low Friction” Upper Ball Joints (20032LF) (already on car)
AFCO “Low Friction” Lower Ball Joints (20039LF) (already on car)
QA-1 Front Coil Over Kit (GMP 1450-3) (already on car)
QA-1 Coil Over Bearing Kit (7888-109) (already on car)
QA-1 Coil Over Spanner Wrenches (T114W)
QA-1 Rear “Stocker Star” 12-way ADJ (TC1661P) (PAIR)
Air Lift 1000 Leveling Drag Bags (pair) (60844)
Custom Ordered GN/Regal Rear Frame “Notch” Kit (¼” steel plate) (NOT installed)
Custom Designed Dash w/AutoMeter Gauges (160mph Speedo, fuel level, fuel pressure, volts, vacuum, oil pressure, oil temp, water temp, trans temp w/custom “Trans Brake”, “Line Lock”, “NOS Ready”, “NOS Active” and “Highbeam” lighted side panel)
The original 200-4R transmission case (dual bell housing bolt pattern, BOP and Chevy) goes with also as well as original factory driveshaft
Painless 18-Curcuit complete wiring harness
(2) Casper’s Electronics GM “Weather Pack” Kits for wiring
New in original GM packages…. Both Doors, Both Windows, Cowl and Trunk Weatherstripping (Try PRICING THOSE!!)
Summit Aluminum 20 Gal w/GM sending unit fuel cell w/foam
I hope I got everything, this car can be sold in many ways. See my other forsale post and I can do a package with any of the other parts. The car is located in Decatur IL.$8500.1-250-474-0622....Chris
more pics
More pic's, also I forgot to list the New exhaust system. Torque Tech 3 ½” “X” pipe exhaust to 3” outlets exiting “GN” style behind rear tires
3 ½” and 3” Pre-formed Stainless Steel Band Clamps for above entire exhaust system included (will NOT “kink” pipes thereby “interlocking” and making disassembly nearly impossible!)
more
More pics
more!
more pics
More
more
Is the price a typo on this? You may want to do more research on these cars and what they're worth. GLWS
You might want to do your own research before you go on someone's for sale thread talking BS, put pen to paper and do the math, tell me smart ass how much money in parts alone are in this package? This pisses me off, if you are not interest and you don't have a clue what your talking about why are you posting on someones thread and trying to screw up there sale? I can just as easy take all my **** and leave. There is a black car post in here for $5500 that doesn't have near the parts etc this project has, did you reprice his car? Chris
More parts
I would like people to understand, all this stuff belonged to my buddy that passed away a couple months ago, one week before his 43rd B-day so as I find things I will add them to the list. There are two cars and a wack of parts to go through so I might miss a few things that are there for this car. I wanted to change the price to $7800 before turbobuick.com's price expert got on my post but for some reason it won't let me edit my post? Anyway, I found the pic for the rad, its a Be Cool Aluminum Radiator part#(62008) this is a $700 rad. Sorry for going of but the board admin might want to use the rule that works great on other web site's that if you are not interested in buying the item (DO NOT POST) Thank you..... Chris
Dash
Where did you get the NOS, High Beam overlay?....Sorry for the hi-jack GLWS.
The dash was was all custom built unit, I think we have the receipt in the file if you want me to look. I think that is part of the reason why it cost $1500 to have built, the workman ship is excellent.... Chris
Date is wrong
The date in the pic's are not correct, these were taken a coulpe weeks ago. The battery was dead and my buddies nephew didn't know how to reset it. lol
If anyone in worried about me being knew here, I have been a member of V8buick.com since 2002 and Have never had a single problem with any of the many sales I have had over there. Chris Skaling
Thank you Mike.
Seems like a good deal to me.I think there $8000 just in new parts and rear end.Good luck with the sale.
For people that are questioning the value here before I posted this add I put pen to paper when I put a price on this car and parts, no typo and yes I did all my research, this is just part of what I came up with. I gave up part way through because my typing finger hurts. :)
NOS Power Antenna from Kirban $250 (kirban re-pop is $170)
Pair of NOS GM, Delco Front Bumper “Energy Absorbers” $150
GM lightweight aluminum front bumper support$400
(4) NOS “T-Type” Center Caps w/ (2) custom made rear adapters for the American Racing “Vector” T-Type “look-a-like rims $300
Kirban Rear Sear Frame Brace kit $73
Kirban Front Frame Brace kit $47
Kirban Driveshaft Safety Loop (already on car) $35
Kirban All New Body Bushings incl. “GNX bushings” (already on car)$290
Prothane Urethane Body Bushing Kit (complete incl. “GNX bushings“) (7-132-BL) $100
(2) Pair of Summit Racing Drilled and Slotted Front Rotors (Cryo‘d), (1) pair on car $180
SSBC Front “Quick Change” Aluminum Caliper (w/HP brake pads) Kit (A181) $500
Global West Tubular Upper Control Arms (TLC-88) (already on car)$460
Global West Tubular Lower Control Arms (TLC-TLC-88H) (already on car)$540
AFCO “Low Friction” Upper Ball Joints (20032LF) (already on car)$40eax2=$80
AFCO “Low Friction” Lower Ball Joints (20039LF) (already on car)$40eax2=$80
QA-1 Front Coil Over Kit (GMP 1450-3) (already on car)$902
QA-1 Coil Over Bearing Kit (7888-109) (already on car)$26
QA-1 Coil Over Spanner Wrenches (T114W)$17
QA-1 Rear “Stocker Star” 12-way ADJ (TC1661P) (PAIR) $280
Air Lift 1000 Leveling Drag Bags (pair) (60844)$80
Custom Ordered GN/Regal Rear Frame “Notch” Kit (¼” steel plate) (NOT installed) $150
Custom Designed Dash w/AutoMeter Gauges (160mph Speedo, fuel level, fuel pressure, volts, vacuum, oil pressure, oil temp, water temp, trans temp w/custom “Trans Brake”, “Line Lock”, “NOS Ready”, “NOS Active” and “Highbeam” lighted side panel) $1500
The original 200-4R transmission case (dual bell housing bolt pattern, BOP and Chevy) goes with also as well as original factory driveshaft$200
Painless 18-Curcuit complete wiring harness #10202 $390
(2) Casper’s Electronics GM “Weather Pack” Kits for wiring$160
New in original GM packages…. Both Doors, Both Windows, Cowl and Trunk Weatherstripping (Try PRICING THOSE!!) $400???
Summit Aluminum 20 Gal w/GM sending unit fuel cell w/foam (car was going to run on E85) $250
New moser 9 in with 35 spine axles, brace, brake kit. $1700
H&R partsNstuff anti roll bar. $529
Becool aluminum rad $700
OK, I quit, just the parts list here NOT including the rest of the HR stuff etc, H&R adjustable uppers, H&R lowers, new tires front and rear, etc etc etc etc etc, how about the rust free org paint car with nice int, how about all the labour put in to this car. Any way I have done my home work and anyone that knows what they are looking at can see the money that has been spent here. Just for the list of parts above the total is $10,689 and there is alot more parts not accounted for on that list. All these parts are NEW. Chris
Exhaust system
Someone just reminded that the new Exhaust system with X pipe wasn't priced out in my list, that is most likely somewhere around $800 to add to the growing cost to buld this car? Chris
sorry im an idiot!!!!!! lol...... heres another stupid question, it's not a t-type just reg regal that he was doing right...
It was being built as a BBB regal, so the exhaust would be different. There is no stupid questions here, ask away.....Chris
