t-type/grand national
will trade or $15,000.00 oe partial trade
Motor bored .30 over with Speed Pro Power forged pistons and Speed Pro molly rings
Crankshaft turned and balanced
Rods checked and balanced
ARP Main and rod bolts
Melling high volume oil pump kit
x3 roller cam
M@A Aluminum Heads with Crane Gold Race 1:6 Rockers
ARP Rocker studs
M@A hardened pushrods
arp head bolts and throughout the motor
Intake polished and ported to match Aluminum heads
Upper plenum ported
Mitsubishi TD-07 Turbo originally sold by Cotton's performance
Ford powerstroke intercooler (front mounted)
3" stainless piping to intercooler and intake
Blitz super sound blow off valve
3" down pipe to a custom 3" to 2 1/2" exhaust with flowmaster
Walbro 340 255lph fuel pump
Casper fuel pump hot wire kit
Bosh adjusteable fuel regulator
55lb fuel injectors
Optima Red top Battery
Accel fully sequntial DFI ecm (with calmap software for laptop)
Adjustable boost controller
3 bar map
New coil pack,Denso O2 and sensor igintion module
Transmission is a rebuilt(100 miles or less) TH400 with reverse pattern and trans brake
9" 3500 stall converter
Aluminum TCI deep fin trans pan
External trans oil cooler
B@M Mega shifter
Moser 33 spline axles with new Moser full spool 3:42 rear
Moser c-clip eliminators
Competition Engineering adjustable drag shocks (Rear set at 50/50 Front 90/10)
Airirde air bags in new Kirban progressive springs in rear
15x8 and 15x7 centerline telestars with drag radials and new good years on the front
CAS Radiator Core with 160 Thermostat
iEquus Gauges
the car is really clean no rust and the color is like black cherry
this is one bad buick
x3 roller cam
ARP Rocker studs
Upper plenum ported
55lb fuel injectors
3 bar map
B@M Mega shifter
iEquus Gauges
