Last summer my 86'gn started a new problem with high bl #'s and eractic o2's.i checked for vacuum leaks with carb cleaner with no luck.i could not get my hands on a smoke machine so i decided to reseal the intake manifold.i just installed a new fel-pro gaskets on manifold and valve covers.i also resealed the plenum,throttle body,valve block and egr while checking vacuum hoses.i also installed new 30lb green stripe injectors while the manifold was off.(factory injectors would not hold pressure)
i just started the car today and thought i had fixed my problem because it now would idle cold unlike before but after it warmed up my scanmaster showed the eractic o2's like before.
Scanmaster readings hot are:
O2'#s 109 - 816
iac #s 26 - 30
af #s 05 - 06
l8 #s 35 - 42
int #s 125 - 136
bl #s 142 - 148
clt 160
ats 97
the car is mostly stock with a lt1 mass + translator,3" exhaust,gutted cat,9" k&n,adjustable gate & feul pressure reg.,hp feul pump + hot wire,poston thumb wheel chip.
O2'#s 109 - 816
iac #s 26 - 30
af #s 05 - 06
l8 #s 35 - 42
int #s 125 - 136
bl #s 142 - 148
clt 160
ats 97
