1987 Buick Grand National - 63,000 Miles
2nd owner. Carfax available upon request - clean! Partial frame off restoration. Everything new at 52000 miles, restoration fresh in 2000. Won the Woodward Dream Cruise Show at the Fairgrounds as best of class 1970 & up muscle car and Judges Choice awards. 2007 Slone Car Show in Flint MI TOP 75 out of 500 cars.
Professionally Rebuild Engine: 3.8L LC2 Block
Stock Rods-(Reconditioned)
Stock Pistons-(Reconditioned)
Stock Crank .010 under
Block Decked and Cylinders Honed
Line Bore for Girdle
Modifications Include:
RJC Girdle W/ ARP Studs
Melling High Volume Oil Pump
Braided S.S. Oils Lines W/ AN Fittings
B&M Oil Cooler
New Oil Pan
Heads:
Special R&D Factory heads W/O EGR Ports
ARP Studs
Ported and Polished
Stock Valves & Seats
New Seals
Cometic Stacked Steel Shim Gaskets
Valves Reconditioned W/ Three Angles
Champion Roller Valve Covers
Valve Train:
T&D Roller Rockers Arms 155 Degree Lift
Comp Cams Roller Lifters
Comp Cam Roller Cam Shaft 206/206
Double Roller Timing Gear & Chain
Fuel System:
Stock Lines
Applied Technologies Dual Pump RP354-6P
#60 Mototron Injectors
Billet Adjustable Fuel Pressure Regulator
Stock Fuel Rails
Intake & Throttle Body:
Stock Ported & Polished
Port Matched to Heads
S.S. Bolts
3” Coated MAF Pipe
MAP Converted (NO MAF)
Ignition:
Stock Coil Pack
Magnacore 8MM Wires
Stock Plugs
Exhaust:
Terry Houston S.S. 3” Downpipe W/ Dump
FJO Wideband O2 AFR Sensor & Gauge
Greddy Profec B Spec II Boost Controller
Turbonetics Evolution Waste Gate
Hooker Duel Exhaust & Chambered Mufflers Jet Hot Coated
Stock Headers Ported and Coated W/ S.S. Bolts
Precision PT 61 Turbo Extreme Heat Coated
Mease Powder Coated Stretch Intercooler W Aluminum Scoop
Transmission:
Stock 200 R4 Rebuilt
Art Carr Shift Kit
Art Carr 9” Converter 3200 Stahl
Chassis:
Stock Rebuilt
Boxed Rear upper & Lower Control Arms
Stock Gear
PST Urethane Graphite Bushings
Painted
Body:
Custom SUPER Straight Paint PPG Paint & Concept Clear Coat Color Sanded Show Quality
Photos: I'm working on a page on cardomain.com right now. Will post that link later today, 10-9-07.
Asking Price: $32,500. Serious inquiries only please.
Copy of appraisal available; appraised at $40,000.
All questions welcomed. I am notified immediately of responses through this forum. Thanks for your interest.
B&M Oil Cooler
New Oil Pan
Heads:
ARP Studs
Ported and Polished
New Seals
Valve Train:
Fuel System:
Stock Lines
Stock Fuel Rails
S.S. Bolts
3” Coated MAF Pipe
Ignition:
Stock Coil Pack
Magnacore 8MM Wires
Stock Plugs
Exhaust:
Transmission:
Art Carr Shift Kit
Chassis:
Stock Rebuilt
Stock Gear
Painted
Body:
