87 coilpack conversion questions
NOKA72
hey whats up guys...im looking into doing this conversion this week..so i need to be sure..
1. which plug wires do i use 85 or 87??
2. all i need is the adapter plate and wiring adapter from caspers??
3.87 coilpack and module....correct...that should be it right.
thanks vinny
hey check out my other thread on cam sensor help...thanks
plugwires? you mean firing order?
i forgot but, if you really meant plugwires, use the hotair plugwires..
right, wiring adapter and the plate, unless you want to rig it like me (you dont )
and the coil and module ,, yeah..
hey nick let me ask you this since you brought it up....the firing order on the coil pack will have too be changed????
and yes my first question was meant for which plug wires to use..concerning lenght and the such.
use your old plug wires cause the coil pack on the IC cars is in the back, ours is on the front dr side so the length's the same no matter which pak you use.
i will go outside and see what wires go where and let you know in a few minutes.
when leaning over the front of the car the back 3 posts of the coil go like so: 4 2 6
