westcoastgrandnational
- May 28, 2014
exhaust leak has already been fixed and made no difference either in how the car runs
SignUp Now!Maybe I am misunderstanding but the cam sensor is what allows us to have sequential fuel injection rather than batch style injection. Our coils fire based on the crank shaft sensor and waste spark during each event. While the cam sensor may prevent the car from starting it can be unplugged while running and the engine will still run. The ECM just needs an initial valve reference to know when to spray the fuel.
Hmm, looks like we are saying the same thing. I agree the engine won't start without the cam sensor as the ICM needs the initial reference and I have no doubt rotating the cam sensor while running will change the fuel injector timing. Are you saying that the ignition timing will also change after rotating the cam sensor while it is running? If so, then I have learned something new. Also, it's worth noting I'm not trying to be argumentative, just trying to have a solid understanding. Thanks in advance.The 'slow start' Buick ignition system requires the cam sensor to know when to start firing the coils. Once running the ICM will retain the firing sequence even without the cam sensor input.
Try this, loosen the cam sensor retaining bolt a tad, start the engine, then rotate the cam sensor. Let us know what happens.
You are correct about the SFI fueling, the ECM requires the cam signal to sequence the injectors.
RemoveBeforeFlight
Yes, dependent upon which way the sensor is rotated the spark will either advance to the next set of cylinders or fall back to the previous set of cylinders. When the cam signal is present the ICM will resync to it on a continual basis. This is why setting it correctly is so important, when it is 'not quite right' the spark can fire on the wrong cylinder. Most of the time this is intermittent and drives the owner crazy.
The change in injector timing would likely not even be noticeable.
RemoveBeforeFlight
And there will likely always be !Seems there is still confusion after 25 years.![]()
That's not true. The cam sensor has nothing to do with ignition timing. It locates #6 for the sequential injector firing to work and be timed properly. Ignition timing is controlled by
Im glad someone with experience/knowledge cleared this up, ALOT of GN owners are misinformedThat's not true. The cam sensor has nothing to do with ignition timing. It locates #6 for the sequential injector firing to work and be timed properly. Ignition timing is controlled by the crank sensor.
Gosh, now my head hurts, went from a cam sensor to a vagina, what a forum.
Why would you want to turn a cam sensor on a running engine can intentionally cause a misfire (or a backfire)?
And what part of that post to you dislike, gnjones231?
The true part, or the part where somebody might actually learn how that sensor actauly works?
