- May 28, 2001
87 GN
TA block 3.950 bore BMS 3.625 crank
Cunningham 6.50 rods
TA heads ported and polished
Comp 244 cam
96pph injectors
FAST bank to bank
76 GTQ S trim ball bearing turbo
TH 400 trans with programmable air shifter, trans brake
Art Carr 3800 ( the real one ) N code converter
16 Volt battery and charging system
Ford 9 inch rear with 3.88 gears. HR Parts sway bar with adjustable upper and lower control arms
Full cage certified to 8.50
Car made 840 hp and 890 lbs ft torque AT THE WHEELS on the dyno.
This car runs 9.50 at 140 mph.
Just put the key in it and strap up.
The price is $35,000. No BS and no experts telling me what its worth.
All REASONABLE offers will be considered.
Comp 244 cam
96pph injectors
FAST bank to bank
