87 Gn
Lee Thompson
The gray on the upper door panels--what can be done to them short of replacing them to make them look good again. I was thinking about upholstry dye--and if so what color. Has anyone tried this? Thanks
Lee, the wife actually did a set with the Sems in the spray can. She use two colors to get a blend that she wanted. presidio gray & a silver, you not would believe how good they came out, we get compliments on them all the time. She’s even had request to do other sets. If the batt.s in the camera wasn’t dead I’d post some pics.
Are you saying
She sprayed 1 color then went over it with another? Thanks for your reply.
Yep....base color was the sems presidio gray (get a complete covering of the panel), after that dried she then came back with a light foggy/mist (over complete panel) of the silver to add a little highlight, at that point she took a clean rag and rubbed the panels vigorously. After they completely dry brushed then with a stiff brush so they are not stiff.
