romadmartin
Car gods son
- Oct 7, 2008
For sale original 85 T-type converted almost completely to a 87 GN/GNX all the stuff is there full 87 GN interior gnx looking gauge cluster with stewert warner guages. whole interior is new carpet to dash to headliner. trans is rebuilt rear end rebuilt with eaton posi and stock 3:42 gears. Engine is 87 20 bolt oil pan block with stroker kit Scat crank, Rods, and Diamond pistons. RJC girdle, ARP studs on everything. new Gn1 thick casting aluminum heads. Comp cams Hyd roller cam, morell roller lifters T and D roller rockers behive roller cam springs. Champion race intake manifold. Turbonetics 62-1 t4 with F1 wheel custom manifolds down pipe. Deltagate. turbo tweak chip. 62 Lbs injectors. 340 walbro new gas tank and sending unit assembly. Front mount intercooler custom made specifically for car. Bilstien shocks. More to list Im sure and probably forgot some. Need to sell with baby on the way. 15,000 or best offer. 20,000 in engine alone but as anyone knows its cheaper to buy then build.
