Wrath
I love boost
- Sep 18, 2015
Hello everyone!
My name is Ryan and I'm located just North of Dallas, TX.
Buckle up
I bought my 87 grand national sight-unseen on eBay back in august of 2015 and have been lurking these forums since then (my join date). I drove it a couple days for the first week I owned it, added less than 15 miles to the 77k on the odometer, (left me stranded) then it went on jack stands since then.
From knowing nothing about turbo regals or about how to work on cars then, I spent hundreds of hours researching just about everything on turbo buicks that I could and spent another several hundred hours (and $$$) replacing parts and restoring my GN where I find time between college and working. I finally got it all put back together and started it earlier last month (Jan 17').
From what I can tell, the car sat for nearly 10 years as it was last registered in 2008, but may have been abused before I bought it. The wiring throughout is a huge mess and one of the rear tires was bald from a burnout, aka no posi
. The car lived its life in Florida, Louisiana, and Mississippi, leaving interior metal components with surface rust, yet the frame and body are pretty clean. Paint is not in good cond. with scratches, large chips, and some rust bubbles.
Modifications it came with:
77k miles - stock block/turbo/converter, Reds 93 chip - Hotwire kit - 42lb injectors - Accufab fuel reg - LT1 MAF and translator - underdrive pulley - front mnt intercooler - Be COOL rad w/ dual Intrepid fans - Atr Headers - 3" down pipe - High flow cat - unknown mufflers - missing thermostat - A/C leak - Cracked hood strut mounts - t-top weather strip cracks - big passenger exhaust manifold leak - rear diff leak - vacuum leaks - crushed body bushings - speedo and rpm in gauge cluster not working - Hood liner sagged and chewed up by alternator fan and turbo - Missing Antenna - Melted plug wires -
Some Additional Pics Here
Just realized my ECU may be a Re-manufactured unit looking through these pics.
Also, One of these: ATR EMC-10 fuel-air-spark control module.
From what I could find online, it's pretty old school tech. I'm not sure if the knock detector works, it beeps when I flip the switch. The spark adjustment knob doesn't work with the Reds 93 chip if I'm correct, and the fan button is disconnected. The Air/Fuel gauge works though.
What I did:
A few Additional pics Here
Upon first startup, heard an engine knocking sound for like 1 second then went away(maybe piston slap?), oil pressure around 65psi, idles like crap and wants to stall until warmed up and in closed loop (might be old gas, Reds chip too). Scanmaster shows bat at 14.3 volts. When warm, there is loud lifter tick near cyl #2 on pass side and a knocking noise near the bottom end like the pulley or something, I took a video Here .
Also, the car doesn't like to *Crank over when warm, which I was unaware of when I went for a drive shortly after I got it, and shut off the car. When I turned the key to the start position, I would head a faint click from a relay under the hood, the water temp light flash on the dash, and the interior lights would dim. This lead me to leaving the under-dash switched radiator fans on to cool the car for slightly too long, draining the already weak battery, and leaving me stranded.
3 hours later, AAA saved me. And no, the car was not overheating.
Still wont start when warmed up to this day. After I searched throughout the forums and put some thought to it, i believe that my Fusible link wires near the starter are no good, heat from nearby exhaust heats up the fusible links and restricts current flow, increasing resistance. I guess I need to replace those now.
Also noted a weird metal creaking noise from under the car when in reverse with the brakes applied, but not when in drive.
As she sits currently:
Buckle up
What I did:
- I've done all of the Spring Cleaning except the diff fluid change. (Didn't Forget ZDDPlus)
- Bought a Scanmaster
- I swapped the power master to a Hydro-boost system.
- Fixed leaks from valve covers, oil pan, transmission pan and cooler, p/s pump, steering gear shaft.
- Rebuilt rear drum brakes and replaced front calipers with new shoes/pads/hardware.
- new tie rod ends, sway bar links, some vacuum lines, o2 sensor, plug wires, wheel studs
- Replaced leaking copper exhaust manifold gaskets with graphite ones found in back seat; remflex for turbo. Heat Wrapped manifolds.
- Flushed block and rad with external water pump, installed fresh coolant and 160* thermostat with 1/8th hole drilled, RMI-25
- trans pan drain plug
- bought some eBay front+rear bumper fillers
....(srry spoolfool) - Found and bought a concert II sound radio and wiring harness connectors, replacement gauge cluster, steering wheel and GN horn button
- repaired stripped threads in the transmission for the pan bolt
- Compression tested, all Cylinders around 150-160psi
- adjusted TV cable, TPS to .44, IAC to around 30
- primed oil system before starting
