’87 Regal Limited Turbo, 10,800 ORIGINAL MILES, purchased in April of 2004 from BoardMember (TwoBryans) with 6200 Original mi who purchased it from the ORIGINAL FEMALE OWNER in NorthCarolina. I have all her Paperwork and State Inspection Receipts.
Car is MINT in every respect except that the Top Surfaces have some paint fading (see photos). The ONLY non-Stock item on the car when I purchased it was the Battery, it even had the Original Air Filter! I did all the Maintenance and Applied the Basic Recipe, flush and fill of the Radiator several times with RMI, Obviously Multiple Oil Changes, Trans Fluid several times, all GM Filters. Plugs, wires (kept numbered originals), Fuel filter, PVC, cleaned & Flushed Intercooler, bled the brakes and installed new fluid, serviced rear twice, new O2 sensor, checked all Operating Parameters on Turbolink. Dropped the fuel tank and installed new Walpro 340(high Volume) pump & sock, New Powermaster Accumulator. And generally cleaned the car up and took it to several shows & cruises this past Summer. The Original Tires (Eagle GT’s) are in great shape as is the Original exhaust. Every Option except T-Tops, of course that includes 6 speaker Concert Sound, equalizer Radio, Power Antenna, Original Factory Floor Mats, Factory Trunk Kit, Overhead map lights. The car is VERY quiet and tight, and of course BRUTALLY fast!! I have ALL Receipts from myself and the Original Owner.
As stated above, everything works Perfect and the car is Tight, any questions just call me at 610-927-3492. 14,400 FIRM
http://share.shutterfly.com/osi.jsp?i=EeCNGTdi0ctXSw
