87 motor for sale machined + other goodies
yarbeau
Darth Vader
I have a ton of parts for sale. All are off an 87 GN. Everything was in good working order on the car.
I would really like to move EVERYTHING at once for 3000.00 which is an unbelievable price. I'm moving and dont want to move it again. machine work alone was 1600, and everything has 0 miles since machine work.
Pics are located Here >>>http://imageshack.us/g/1/9849837/ and more here>>http://imageshack.us/g/1/9849849/
Please go have a look and email with any questions, or if you require more pictures :)
1- Under car intercooler shroud -$20.00
2- Stock valve covers great shape - $60.00
3- stock good condition oil cooler lines - $50.00
4- fuel rail with fuel pressure gauge and regulator - $90.00
5- water pump- $40.00
6- belt tensioner- $50.00
7- throttle body- $100.00
8- stock Starter- $50.00
9- misc vacuum lines and canisters? $??
10- Front time chain cover assembly- $65.00
11- Alternator - $90.00
12- Harrison AC unit - $190.00
13- fuel lines- $??
14- stock intake manifold with RJC power plate - $260.00
15- motor mounts - $??
16- flywheel - $? no idea
17- timing chain and gear - $??
18- tomco 32lb injectors (green label) $50.00
20- flat tappet lifters and pushrods - $??
21- aftermarket pistons freshly machined with zero run time, bored .030 over. (work done to pistons: hone pin bore on pistons and rods, resized rods and installed pistons on rods.) only selling with block and crank as they are machined to go together
22- coil pack - $30.00
24- stock oil pan - $offers
25- harmonic balancer - $140.00
26- chrome turbo heat shield and bracket - $160.00
27- Stock overhauled heads with zero run time. (replaced valve guides, hones guides, 0.0025 over, valve job, checked springs and reassembled, face was ground true) -$? offers
28- Stock machined crank zero run time (mag, grind and polish crank) -$goes with block and pistons only
29- Cam sensor - $ 70.00
30- injector wiring harness - $40.00
31- Coolant tubing - $45.00
32- K&N rocker breathers - $35.00
33- K&N cold air intake with piping and stock AC delco NON REMANUFACTURED MAF -$ 260.00
34- coolant resevoir -$25.00
35- Up Pipe with alky control nozzle - $65.00
36- Block Bored .030 over. zero runtime since machining (Mag, deck, check block, Resurface block, hone cylinders) $ includes pistons, crank, block all ready to go $2k
Please send me offers if you guys wouldnt mind. Machine work alone cost me 1600 + dollars... All work done at Moretto Motorsportz (campbell automotive) in Edmonton, AB. Have photos of everything. if you're interested email yarbeau@gmail.com or PM
Derek
I would really like to move EVERYTHING at once for 2800.00 which is an unbelievable price. I'm moving and dont want to move it again. machine work alone was 1600, and everything has 0 miles since machine work.
13- fuel lines- $??
19- T&D roller rockers 1.65 ratio - $450.00
23- Maf translator with (i believe) LS1 maf and wiring adapter. - $ 265.00
Derek
Interested in the intercooler shroud can you email me pics can't see on the link you posted. Email is beacockjosh@yahoo.com thanks man
interested in fuel rail guage and regulator and 32lb injectors and belt tensioner if not already sold. Is it a stock fuel regulator or adjustable
