turbowannabe
- Dec 6, 2001
Well as my financial situation gets worse and worse every day I have to sell the T to try to turn everything around. I bought the car early this year from the member FATRIDE on here. Drove it for a month and blew a head gasket while boosting 16 lbs on a hot day with 93 octane. Gasket blew into the lifter valley so no coolant got into the oil.
The car then sat in my driveway for like 3 1/2 months until I finally got around to fixing it sometime late last month. Drove the car for one day after fixing the head gasket and started to hear a knocking noise after only boosting 10 lbs. Immediately after hearing the knock I stopped driving the car and had intentions of pulling the motor out over the winter. I have come to realize I am broke and have no time to deal with this so the car needs to go.
Sounds to me like a main bearing has gone south. THE ENGINE ONLY KNOCKS WHEN IT IS UNDER LOAD, and I've heard a rod bearing go out before
and this is more like a low pitched noise.
Basically everything you need to know is on either of the links below along with pictures of the car. CAR HAS ABSOLUTELY NO RUST AND INTERIOR IS IN AWESOME CONDITION.
http://www.turbobuick.com/forums/showthread.php?t=183509
http://www.turbobuick.com/forums/showthread.php?t=170471
-TE44 W/ .63 Precision housing
-Jimmy's Trans with Hardened Drum
-Art Car 9'' 3400rpm stall Non-LU converter
-HD rocker shafts
-Fresh 8445 Heads
-ARP head bolts
-ARP main studs
-Mease SS plenum
-Polished 58mm throttle body
-Scanmaster V2.1
-42.5lb/hr green stripe injectors
-Turbotweak chip
-ATR double pumper
-Billet fuel regulator
-10mm spark plug wires
-Mease SS 3" downpipe with dump pipe
-Cottons 3" singleshot with dynomax race muffler
-Precision turbo saver
-Auburn posi with 3.90 gears
-moser axles
-rear air bags
-Weld draglites
AND MORE!
I paid $7500 and spent even more money on getting the heads resurfaced and cleaned and I bought the Scanmaster that goes with it. The car would be great for someone to pull the engine over the winter, freshen it up and put it all back together the way you want it. I would like to get $6500 out of it. Let me know if your interested or need any more information
PLEASE EMAIL ME ABOUT THE CAR THAT IS THE BEST WAY TO CONTACT ME.
-Dan
-HD rocker shafts
-Fresh 8445 Heads
-ARP head bolts
-ARP main studs
-Mease SS plenum
-Scanmaster V2.1
-Turbotweak chip
-ATR double pumper
-moser axles
-rear air bags
-Weld draglites
AND MORE!
-Dan
