SignUp Now!Map sensor hard to see but your boost reading is -29 hg and never moves and doest look like map reading never changes either
Check wiring to maf i had a similar issue and it ended up being a bad ground to the maf i ohm all my grounds after that to make sure they were all good
Yeah sometimes these cars can be a pain in the ass. Does it still have a cat maybe its clogged just throwing things out there i know the frustration i did a pressure check on my hole system when mine was giving me fits made a fitting out of pvc and caps for exhaust used a cig5for the smoke and put 20 psi or so in
Previous owner added a ground to the MAF and it is hooked directly to the post on the ground extender to which I have added a ground directly to the neg post of the battery.
Yea I would say thats a safe bet. Buy the connectors from Casper Electronics and I would highly advise using heat shrinkable butt connectors with sealant on all connections. You could also solder and heat shrink to save space but I prefer the butt connectors and stager the lengths so they arent all in the exact same spot. Also, obviously thr water intrusion needs fixed too if it hasn't been already.![]()
Pretty confident I found my problem here......
No trees were harmed in the sending of this message, however, a significant number of electrons were terribly inconvenienced.
When the prior owner had the MAF issue, Razor diagnosed it as a possible bad ECM, or bad wire from MAF to ECM. Glad you found the problem. Can you tell from receipts when the leak was fixed? You might want to check for rust on your floorboard.
May not have been the w/s.has a pretty new windshield) so my guess is the windshield leaked at some point...
Looks like I will be pulling the heater box and resealing it! The sealer is all dried up and cracked with big chunks missing.May not have been the w/s.
The ac box to cowl is much more likely to be the source of the leak. Check the sealer at the edge of the box. It gets hard, cracks, leaks.
