Chazzworth
Custom User Title
- Jul 28, 2008
This car is built with huge Turbo, Built Motor, Trans, Rear end etc... Tons of money in this car over $15k O-ringed heads rods Alcohol injection kit and tons more. . The tranny was around $3k alone. from Performance Transmission Services A fast car in a ugly shell. Not currently registered.
New $1200 Rear end new Eaton posi 3:42 8.5 Factory GN gears bearings axles.
Performance tranny ~ built by Bruce
Stock Converter
Motor
Balanced ARP rod main and stud head bolts forged pistons aftermarket rings .30 over bore. Mild RV cam
Ported o-ringed heads for lock wire head gaskets. Stainless swirl polished 1 piece valves from Manley 194-150 Aftermarket valve springs Stock rockers double roller timing chain high volume oil pump. Big injectors 36-38? Adjustable aftermarket fuel pressure regulator. Applied technologies 3” down pipe
T34? Ball bearing turbo
Alcohol kit RFL blow off valve
New cat and exhaust
Hot wire kit for the fuel pump
MSD rev limiter
High low boost controller
Eibach springs and Koni shocks
Factory Silver blackout package car No chrome.
OEM turbo Buick wheels
Fuel pressure gauge
Applied technologies pit-bull chip
Throttle body hot water ports plugged off
Turbo charge pipe hoses and clamps
Located in Central CA between Sacramento and Tahoe.
$4600 obo or trade for cash plus ??
Stock Converter
Motor
New cat and exhaust
MSD rev limiter
Fuel pressure gauge
