turbov6joe
Signal 1 J-12
- May 22, 2002
Well if you read the add and my replies you would know several of the answers and saved some time. The motor questions are good but I will have to talk with Bill to insure I give the correct answers.
Here are the answers I do have.
How many billet mains? The Center mains that provide the block with structural integrity.
What kind of fastners on the rod, mains, heads? All ARP
What kind of headgaskets? Real Cometic
Heads or block been milled down? No
What kind of rear sway bar? None. Bags and Solid Lowers.
Is the converter L/U or not? Non Lockup
How many miles/passes on the motor and tranny? Read above on the tranny. Motor has been together for 3 years and spent most of that time in a garage. It is hard to say but 3 old men owned it and we do not tear our stuff up. Thats the best answer I can give for it.
Does it have polly motor and/or tranny mounts? Polly Trans mount. have to ask bill on the motor mounts.
Does the a/c blow cold? Yes
A/C converted to 134? Yes
ANY rust anywhere at all...if so where? Small amount in the Drivers front bottom corner of the door.
Is it a numbers matching motor/tranny/chassis? Yes on motor and chassis not sure on the trans case have ot ask bill
What kind of track numbers has it run with this combo? 6.68 @ 105 1/8 Thats with the 63mm at 26.5PSI on Alky.
What kind of condition are the OE wheels in? Good Condition no Centers
Who's exhaust system and what size? TH 3" Down Pipe, Magnaflo 2.5" Dual Mufflers, TH Dump setup to add the electric if you want, All mandrel bent tubing. Don;t know exactl who Mike bought it from but its nice loke new and it works.
Original paint or not? Has been wet sanded and re-shot with gold and clear last Year with no major body work done to it.It is what you see when you see it in person.
Eric
If you could get answers to the unanswered questions I'd appreciate it.
