87 Turbo T white pearl/maroon interior 10k SE VA
Steve V
Steve V's Automotive 757 560 2782
My 87 turbo T has about 118k on the body. Been repainted by previous owner white pearl, Paint is ok has runs and sags by that easy to overlook with white. Hardtop car.
Details:
Fresh engine 2011
Std bore/std crank
204/214 flat tappet cam
Ta cam bearings
All oil mods to blueprinted brand new GM cover
Smooth stem exhaust valves with positive seals.
Series II wide rod bearings
GT6157 turbo with custom Bison exhaust housing spools great.
60lb injectors/extendar chip
Maf trans with 3.5 maf
F body rad/all new hoses belts.
ATR drivers side header and crossover.
New motor mounts etc
Turbo regal custom parts stretch SLIC.
Dual fans
Harness all retaped
Not numbers matching!
Trans:
Fresh built 2012
9x11 2800 stall convertor
Carbon band
custom shift kit
hardened drum
teflon ringed through out
.500 boost valve
3-2 mod
shifts quick and firm
Rear all stock with 3.42 posi
New u joints and fresh balance on the driveshaft.
Hooker exhaust
stock downpipe
custom cat:)
Interior:
Split bench
Lesabre dash conversion
Boost/oil pressure guages on the A pillar
Door panels are nice as well as drivers seat and back seat.
Needs a headliner and pass seat bottom is ripped
Tinted windows
Suspension:
Bilstien shocks
New front pads/rotors/caliper/hoses
new brass brake valve
new upper control arm bushings
new left front outer tierod end
recent alignment by myself
Gbody parts recondition GTA wheels
tires 225 55 16 front goodyear
rear 255 50 16 Bfg
will not need tires anytime soon.
The bad:
Needs a headliner
Needs pass seat bottom recovered
AC blows hot needs charging
Has minor RF damage.
Cracked the header panel(repaired with expoxy)
cracked bumper filler
slight dent in fendar
I have a header panel that goes with the car/RF filler also
problem will be matching the paint.
Even with this still a sharp car and a header turner for sure.
Price is 10,000
sasybit@ymail.com
757 560 2782
pics to come tonite I am at work now....
Few more tidbits..................
Reason for selling, next step for this car if it stays here is a strip and repaint. That's a major undertaking and I have one getting that right now(not a buick). Mechanically it is ready to be enjoyed. I have put maybe 2k on it in 3 years. I don't need to keep it and would not mind another TR to redo mechanically.
I will consider trades. I want another TR with NO Tops. I really like astroroof cars. Prefer something that is a mechanical project. No rust repair or painting. Decent paint/body interior can be rough:) I don't have a trailor so I will need to be able to drive it home.
I did leave off the 340 walbro, accufab regulator, hotwire kit, new cam/crank sensors, GM coil/module.
Car is pending sale. I will post if it falls through.
Is this car still for sale? Please PM me if it is. I'm looking to get another Buick and I've always wanted a white one.
