87 wastegate actuator bracketry
Toby_Goodmk
Test Fit officianto
Will it fit onto a hot air turbo with any issues, or are there modifications to be made?
IMG_0457.JPG It will bolt right on but it will dig into the hoodliner. See the scratches on the flange? I drilled another bolt hole right under the actuator rod which lowers the height of the actuator and keeps it out of the hoodliner. I will also e-mail you the original hot air instructions. Brad
Have the same actuator as Brad's, also bent the tab on the waste gate end
a bit to keep it square to the pin and doesn't bind... my bracket sits almost level (or flat)
so it doesn't rub hood liner.
