I apologize for a foreign posting, but a very similiar car (ecm) is giving crazy #'s that ive never seen. Its a 89 IROC tuned port. Tps when key on gives a good reading .52 on up. Then with motor on, the reading is .19 to 1.3 volt. And the o2 reading is stuck at .445, but o2 cross counts show perfect. Code does give tps too low, and o2 sensor malfunction. All is new including ecm, and old ecm did same thing, except o2's were correct. Wiring ohms out fine also. Grounds are fine. Has anyone seen this in this generation of ecms? Ive never seen it in a TR. On my 87 GN, for comparison, I did pull the o2 wire off while scanning, key on, and it also just sat at .445. So it would seem the iroc has a dead o2, or open wire, but neither is bad.
Sorry again , but there is 0 info on the pertinant boards.
