SignUp Now!The purpose of having 5 discs is to tolerate WOT lock up. WOT lock up is the only reason the 5 disc was produced. More friction area= more grip/less likely to burn the clutches.It is probably the strongest lock up converter your going to find and I believe the only one designed for WOT lock up. .
Ok, didn't know . So there are two out there for WOT lock up applications.The purpose of having 5 discs is to tolerate WOT lock up. WOT lock up is the only reason the 5 disc was produced. More friction area= more grip/less likely to burn the clutches.
... My tranny guy has installed quite a few of these TC's and there needs to be good clearance between the converter and flexplate so it may need a shimming, ..............
Witch one slips less unlocked
Thanks Joe
Seems like the Vig has a pretty good following here. Tho, I don't my TB stalling on the street.
Thanks Joe
This has been my experience also.It's only when you start them cold and first put them in gear. I tap the throttle and it's fine. It doesn't do it with any heat in the fluid; for me at least.
