HEY GUYS I HAVE A QUESTION...A FRIEND HAS A FREDDY BROWN TRANS(ONE OF THE BUILDERS IN USE HERE IN NEW YORK)2004R WITH A 9 INCH 3200 STALL CONVERTER N/LU HE IS GOING TOO A TH400 SO I CAN GET THIS TRANS AT A VERY GOOD PRICE MY QUESTION IS WITH MY 85 HOTAIR CAN I USE THIS TRANS OR MORE LIKELY THIS CONVERTER WITH THIS SETUP:
STREET CAR OCCASIONAL TRACK DUTY OUT OF CURIOUSITY
30 OVER TRW FORGED PISTONS
POSTONS CAM 107T...202 DUR AND 430 LIFT
30# GREEN STRIPES,STOCK TURBO,MILD HEAD WORK,NO PORTING,160 STAT,ADJ REG,HOTWIRED PUMP,ETCAND FINALLY IF I CAN USE THIS CONVERTER SHOULD I HAVE A CHIP BURNT FOR IT OR CAN I BREAK THE NEW ENGINE IN WITH THE STOCK CHIP...THANKS VINNY PS DO YOU SEE A PROBLEM WITH USING THIS CONVERTER ON A DAILY DRIVER????
