i dont have alot of experience with rearend set ups. excuse the stupid questions. if someone could help me with this. i would really appreciate it. plus i need oppinions on parts! the guy that had it before me, put this set up in it and mini tubbed it. first problem im seeing. the mini tub doe not help at all due to the lower control arm bracket. if i move the control arm up one notch at cut off the bracket, i can tuck the rim further toward the frame. do i cut this? or cut the bracket and move it in? the rear should have been narrowed i guess. then if i do that. does it look like the lower control arm will hit? how is other people doing this? you can see the crap job he did of welding the frame plate on. im going to redo all that but right now it doesn't help at all being notched. lol
[/IMG]
[/IMG]
[/IMG]
here is the driveshaft loop that is attached to the lower control arm mounts. what are the tabs for? lol anyoe know?
[/IMG]
[/IMG]
this is the upper cotrol arm. it is not braced at all. what do i need to do to brace it correctly?
[/IMG]
are the lowers good or should i replace them with adjustibles? they are solid. what about the uppers? they are stock. what shoud i replace them with? i want to set up my rear end correctly ad eed lots of help! thanks guys!
