9 seconds with just billet caps
49-blues
Is anyone running in the nines with just billet center caps and no girdle? Does TSM class allow you to run without a girdle and only billet caps?
Matt
TSM does not tell one how to build their motors. As you approach the low 9 territory, the block needs all the help it can get.
Yes, you can go high 9s with just the centers. Having a forged crank helps alot regardless of billet caps and/or girdle.
Billy T.
gnxtc2@aol.com
Thanks Bill- I was wondering if a forged crank and billet caps would be enough to run in the high nines.
I could be mistaken, but I thought I read that Dan Strezo does not use a girdle on the engines he builds.
It's a little or a lot more complicted then that. Quite a bit of machining to secure the caps is what I am told.
Come on Brett , you know nothing about these cars is complicated :D
Hey I got ur chip. Well, it's kinda urs. I lost the first one and bought you a brand new one from TT:cool: Guess im not gonna need it tho since the XFI will go in when it gets to Ottos house. He says he will just set up an emmissions tune. I will try to bring it by next week. Oh and I see I spelled complicated wrong...:wink:
Thanx - at the rate I'm moving the car will be emmisions exempt by the time it's on the road :mad:
gnmaster2004 in tsm trim in the nines. no girdle, billet mains, forged crank h-beam rods.
off topic but where in NYC are you located? not to many GNs around me (bensonhurst BK)
