Dr.drivability
9 second wannabee
- Oct 1, 2005
Can one safely go 9's on 93 and alky???, Dave
SignUp Now!why not?? we drove to the track .. Melissa ran in street trim like the car is driven an ran in the 9s @ 138 . Then got kicked out. Then drove around for a few hours looking for a place to eat!! ya we got lostI think Alky is the best bang for the $$$.
Never heard that story before! Wow!
Was it racing meth you were using?
Did you have any false knock readings on the shifts or launch?
I remember reading the combo but just can't seem to grasp the fact that it went 138.Certainly not calling you guys liars, but, did any of you actually expect it to go in the nines? IIRC, a 3 bar map, which would mean under 30 psi, and a single walbro intank pump, and Champion Iron heads.
I think 9s and alky is pretty easy to do(relatively speaking). As long as you have a quality build. I went 10.80s with a bone stock long block at 126MPH. Race weight was 3650 and this was in 75 degree weather and a 10MPH head wind. I think it may be able to go 10.50-10.60s on a perfect day. As long as it stays together. :biggrin: But I did not have any knock at all. Not even a blip.
But if you want to go 9s, follow a set up like Grumpy's for a killer street combo. Or go with a more aggressive combo if you want.
i remember following the threads on grumpy's car and there is no doubt in my mind you guy's did what you showed and put it down no talk just results.i believe having the right people around the right parts can go far,although i also believe everything mechanical can fail at any point.i went what i would consider a long time without breakage but eventially paid the price with no knock and a safe afr in my mind and the mind of others with much more experience,sometimes this old stuff just breaks.
Exactly! JCs king right now.....Top of the list!
Damon, you got lots to prove with your GIANT killer this year..... Don't be scared...![]()
