Just wanted to know if you just have to take the spring out and shock out to get the upper a-arm to move around when I take the bushing out (upper right side). It is shot from the heat of the DP so I need to replace it. Got a heat shield from Kirbans that should take care of this ever happening again. The other ones look good so I will not be replacing them for those who tell me I should!
TIA,
TIA,
