hammer1918
- Oct 2, 2011
ya my car idles up and the fan comes on when i short the lo pressure switch but the clutch is not kicking in.
SignUp Now!Black plug. Grey is the fuel pump
. I checked the relay and it has 12 volts but when I jump it the clutch still doesn't energize. By the way this is a friends car and doesn't have a scanner
Is it possible the internal relay contact are burnt?Fully charged. Relay has power too
If you can PM I will email you PDF AC electrical diagramI tried another relay. Everything works and when I put air on the fan kicks on and idle changes but tries to stall because of no load change
Sent from my SCH-I100 using Turbo Buick
You claimed the fan came on and now it dosen't come? What change?
Did the print help you out?
Need more detail
GNONYX said:Try to run a wire from the AC output relay straight to the clutch terminal connection and not the clutch wire itself, and see if the clutch engages.
It engages when I apply 12 volts to the clutch. What wire from the AC relay
You never answer me if you received the AC electrical prints I sent to you.
If you did received them, then look at page 8A-21-3 (AC cutout relay) Check and see if the wire is cut.
thanks got itRmvBfrFlght said:QUIP'6', I posted the wiring diagrams on post 17:
http://www.turbobuick.com/forums/th...-to-green-wire-to-clutch.379975/#post-3045771
Click on the thumbnail, then click the upper-right arrow for 'see original post' or such for a larger view.
RemoveBeforeFlight
Yes I did thanksneed boost said:obvious BUT did you check your fuses under the dash there is one for the ac
which wire on the relayDid you receive the print I sent you?
You apply power from the alternator to the clutch, but did you go from the AC cutout relay on page 8A-21-3 itself to the clutch terminal and see if it engages.
As I stated in the email, is it also possible the ground wires behind the block may be loosen during your installation of the tranny?
