Have you tried bypassing the ow pressure switch to see if the compressor kick on? That's 1 of the most common problems on A/C.
GNRick said:I had the same exact problem. I called CharlieF1 and if I remember correctly the problem was a break in the green wire. Just splice in a wire (preferably green to keep the colors consistent) close to the low pressure switch and run it close to the connection at the compressor. Splice it in close to the compressor and you will have cold air again. So basically you just need to bypass the break in the wire. Also be careful as there are two green wires, one is darker than the other.
Let us know if that fixes it.Thanks rick
Sent from my SCH-I100 using Turbo Buick
will do just got to get time and have a day to work on it. its a friends carLet us know if that fixes it.
Ok, shouldn't take more than 10 minutes. Just stop at parts store and get a roll of green wire.will do just got to get time and have a day to work on it. its a friends car
