A/C Compresser disengage
87T
I know that when you go to W.O.T. the ECM will disengage the compresser clutch are there any other built in features that will do the same thing ????? :) :)
If you have too low a charge, the pressure cycling switch will cause the compressor not to engage.
Along similar lines, does the computer shut off the high speed rad fan at a certain speed?
