The retrofitted R134a system in my T doesn't get cold unless the car is moving. I understand air flow across the condenser coil is important. I still have the factory single fan in my car. I've tried moving it closer to the radiator but that didn't do any good.
I'm thinking converting to a dual fan set up may be the answer. How much of a temp drop in the a/c system do you think I'll have if I do dual puller fans? How much cfm do you think I need to have to draw enough air across the condenser to improve the a/c efficiency?
As for dual fans...I've read some here like the dual Dodge Intrepid fans...I believe 1993-97...right? I've never seen what they look like...is this a pic?:
But I believe I've also read these fans are known to have clearance issues or worse...to go belly up...? What's with that?
I also see Cal sells a dual fan set up....http://www.hartlineperformance.com/frontbox4.html I take it this is a plug n play designed to fit the GN radiator?
Not sure what to do here...thoughts?
