tim87tr
Obsession or Digression?
- Sep 19, 2001
Just installed the larger wheel cylinders and soft rear shoes. Two questions:
1) What do I need to do to get the drum back on, everything is too tight at this point for this to happen. Do I need to bleed the system first, or adjust the circular adjuster dial inwards? (the one at the bottom of the shoes between them)
2) Bleeding the rear brakes, does the clamping of the plunger on the prop valve keep the dirty fluid from traveling upstream into the master cylinder? I know that is something I need to prevent, but my gnttype instuctions do not provide the details I need for reassurance.
Thanks, Tim
Thanks, Tim
