SignUp Now!Thanks. I am using Gen II/LC-1 with tracking.
I have played around with TP enough to know that it is logging but that is it. I would like to figure out how to determine how much fuel to add/remove, based on TP data, in order to get a flat line afr.
  Patrick,
I have an LC-1 wb connected to my Power Logger to record afr and the Gen II to make corrections. I have not really learned the Tuner Pro so I can't answer your question re: add/sub fuel, but I think it does do that. That is what I need to determine and then learn how to read the correction factor so I can program that into Gen II to get a more consistent afr.
I was at Richard's last night and will probably be there this weekend. He is at the garage almost every evening and weekend so let me know when you want to come to Burlington.
How do I save/replay a file? I can find the file I saved when I go to Open File but I can't seem to play the one I saved
--The screen displays at the bottom of the page are really small in height. Is there a way to make them full screen, or at least larger than about 1.5" tall. In Dash mode the six screens are about cut in half, left to right, and it is hard to read the data because I can just read the top half of the data.
