on the left is the 33 spline strange, next to the old moser 28 c-clip axle.
another pic of the 33 strange axle
mating up the ring gear to the spool
spool in place, shimmed to about .008" backlash
pressing the bearings on the axle, these are designed with a unit bearing for oval track and street/strip applications
bolting together the eliminator kit, backer plate for caliper mount can be seen as well
all mounted up, one piece rotor w/4 piston caliper
pads are easy to change as well, including with the kit are hawk softer pads for street use and trap speeds under 150mph
special thanks to pacecarta, who did all the work while i drank coffee and took pictures
