BUICKTIME
just another member
I’m selling off some of my parts. All parts are brand new unless otherwise noted. New means new as if you ordered it from any of the vendors. I have a lot more parts for sale, but these are some of the parts up for sale. Remember all parts are including shipping to the lower 48 states (unless noted). There is a 3% paypal fee. These parts must go, no reasonable offer will be turned down!!! Plain and simple, snooze and you loose. I just don’t have the time, so please don’t ask and waste my time if you have no intensions on buying, serious buyers only. Trying to make it as simple as possible. Some of these parts have been relisted because they were never paid for. Again dont waste my time if you have no intensions of buying.
TIA Mario
Brand New Chrome & Polished parts.
Chrome:
Southeast alternator $250
RJC alternator fan $30
Master cyl. Cover (not the cap) $24
Heater water valve (2pc set) $25
Windshield washer cap $13
Fuel psi. regulator 90 deg. Stem $8
Fuel psi. regulator cover/cap $8
A/C drier cover $22
EGR cover $22
Power master accum. Bowl cover $13
Power steering cap/cover $10
Power steering reservoir bracket $33
Water reservoir cap $13
Heater blower cover/cap $22
Custom fan sensor bracket cover $20
Polished:
RJC/Accufab 70mm Plenum $240
RJC alum. Racing crank pulley $140
RJC alum. Racing water pump pulley $80
RJC alum. Racing idler pulley $70
RJC alum. Racing pwr steering pulley $70
RJC alum. Racing alternator pulley & nut $43
D.C. tech alum. Turbo shield (Buick Racing) $250
Billet t-stat housing w/seal $22
Billet t-stat housing bracket/holder $10
S.S. EGR vacuum valve cover $20
S.S. battery bracket $15
S.S. stock MAF cover $22
S.S. pass/side sensor bracket $15
Billet driver side oil fill w/filter (not polished) $30
New or like new parts.
T.H. 3” D.P. w/dump $600 (probably the last NEW one around)
Precision TA66 (just rebuilt by Limit Eng.) $750
RJC stock valve cover spacers $90
Wastegate vacuum solenoid $50
Wastegate vacuum solenoid y-hose $25
Casper knock sensor w/blk face (prt#102001) $80
Casper engine ground kit $50
MAF sensor bracket (not oem style) $8
Like new 3 bolt ATR S.S. Headers w/hardware $730
Like new Harland Sharp 1.60 roller rockers (w/shaft support, maybe 50 miles on them) $440
Like new 3” blk MAF alum. Pipe w/hoses (installed just to start and move the car) $60
Like new big turbo inlet bell $45
Used parts
87 GN Dash w/Plaque no cluster & trim (latch broken on glove box, easy fix [no shipping]) $220
Shifter assembly with chrome stalk (chrome is no good) $25
T TOP trim pieces around the t-tops on the inside of the car (minor crack on one piec [4 pcs.])$45
Rock arms & shafts $65
Fuel rail $40
Lower intake $150
Upper intake $65
Throttle body $90
Valve covers (real nice bead blasted/not bead blasted) $100/$65
Stock pair of heads (8445 not shipped) $50 a set
Pro Stars 15x8 w/3.5BS with drilled holes $230
87 Black Grille (slight crack on bottom/back side, cant notice when installed). $185
87 Chrome Grille $110
Aftermarket Spoiler (?) 3 piece $130
Rear Tail Light (cracked lens) $50
Heater box complete (minor crack, look at pics/not shipped) $100
Windshield wiper arms (black) $60 pair
Inner fenders $100 each or $175 for both (not shipped)
Front sway bar $20 (+ shipping)
Gear box: (quick ratio) $40 (+ shipping)
Pictures by Buicktime - Photobucket
Will trade close or equal value part for: Freshly rebuilt stock turbo, NOS roof rail weather stripping, new to very good shape front and rear bumper fillers.
