before i go bald someone please help!! motor rebuilt aprox. 3k miles...when done got new rad,pump,160 stat,cap all new hoses..anyways ran a little warm 190-200 but it was hot days
now for the problem.......got to work the other day and water was flowing out of the overflow wasn't running hot until the water got low of course.... cooled it down checked for leaks and stuff all seemed fine started idled for 20 minutes nothing drove home same thinghappened water just flowed out of the overflow thought it might be a stuck thermostat so changed it drove for a bit no problem went to work today and same thing overflowing out of the over flow.... changed the rad.cap and drove home not gettign hot or overheating but stillpushing water out the overflow no water in the oil and pressure checked the rad holds pressure for about 15 minutes then drops a little very slowlywhen water is being pushed back into the overflow looks like little bubbles in the overflow help pleasegoing crazy with this car...sorry it's so long anyone help the fan is working fine and i put my finger in the water in the overflow and its warm not hot
