Happy New Year to everyone.
I'm planning on finally upgrading my stock turbo and IC to a BB turbo and FMIC this year. Right now, I have a hotwired Walbro 340, 009 42.5# injectors, 2800 stall 9x11 L/U converter, stock heads and cam. I'll probably upgrade the cam when I do the timing chain, sticking with a flat tappet cam.
My question is, since the BB turbo spools faster, does it negate the need for a higher stall converter at all? If so, could I get away with the converter I have now? It may hurt ultimate performance to some degree, I'm just curious as to how much? I'm thinking that it will stall a little higher with the increased torque production of a bigger turbo, but I have no idea how much (engine torque does affect stall speed, correct?). The car is primarily street-driven, with a few trips to the track each season.
I'd like to step up to a turbo in the upper 60-series, with a FM, bigger injectors (65#/72#/83#) and a new TurboTweak chip. I'm sold on the FM....NOT going with a stock location IC. I'm not real worried about overheating, since I'm putting an F-body radiator, external oil cooler, and hi-flow water pump when I mod the car this winter. Right now it has the original cooling system, except for a 160º stat, and it has never eclipsed 185º, even in traffic on the hottest days of summer here in New England.
Eventually, the car will get aluminum heads, just not right away.
Thanks for your input.
Steve
Steve
