About to attempt my version of the "Spring Cleaning " list.
Brief synopsis of the car:
I have a 1987 Buick Grand National with 84k miles on it. Paint sucks.
Its probably been sitting in a garage for the past year or two without much movement. It started right up when I picked it up. But it hesitated.
I dont plan on "racing" this car. Just want a reliable engine and a car to "cruise" around in.
I have a few questions:
- Whats the difference between a Stage 1 & Stage 2 model?
- How do I tell which one I have?
- What viscosity Oil should I be using? (remember its an old unmaintained car.)
- Regular or Synthetic Oil?
- Oil Cap(s)- Regular of the kind with the little Filter Element attached?
- Can the Exhaust be changed using a Jack and Jack Stands or do I need a lift?
- Spark Plugs. Are they easy to access or not?
- Which Plugs are recommended?
- Which Spark Plug Wires are recommended??
- Radiator and Coolant?? Which Coolant should I be using?
- Brakes- Which Brake Fluid (Dot Level) should I be using)?
- Turbo- Any basic adjustments I should make to it? Or should I leave that for later?
- Hood Struts- Is this basic or is there a trick to it??
- Power Radio Antenna- Where can I get one and is it a DIY project??
- And YES , I plan on having David at TBPT look over the car once I get the basic stuff done.
I think thats it for now. Thanks in advance.
