Sep 23, 2001 #1 G GN5 Guest The alum. bracket that holds the a/c comp and the alt has a crack on it, any ideas???? THANKS
Sep 23, 2001 #2 R RSTTYPE85 RSTTYPE87 NOW Joined May 26, 2001 Messages 173 Check with Mike McCoy or Brian Weaver they should be able to get what you need.
Sep 24, 2001 #3 T TType84 cookin with propane Joined May 27, 2001 Messages 1,909 yea you can also get them off of carbed montes, carbed Trs, and normal 3.8 n/a regals.. ALTHOUGH.... they will only fit a wider alternator..
