ChrisCairns
Senior Member
- May 24, 2001
Hopefully someone has come across this problem before.
I put a brand spanking new AC compressor on the new engine before I put it back into the car. I connected the flat dual prong connector to the underside front. Slipped on fine. I then attempted to connect the round connector with 2 holes for prongs inside and a slot in the top to it's proper location on the back of the compressor. It won't go on. I've looked at it with a mirror and it seems as if the prongs are in the wrong spots. (BTW, I can't remember if the prongs are on the compressor's connector or are in the wiring connector so don't take that part of the description as gospel.) And I can't turn it because the slot in the connector must match the riser in the compressor connection.
Anyway, anyone come across the prongs in the wrong place problem. I got the compressor from GMPartsDirect so I assume it's GM.
Thanks.
Thanks.
