1KWIKSIX
- Sep 29, 2007
Don't use the insert that came with your seal kit.
Only use the specific insert from Highway Stars (as it is machined differently to an exacting tolerance).
Have you also replaced your AC line set with the reproduction unit from Highway Stars?
If so, use the insert supplied by Highway Stars and tap it gently (and squarely) into the smaller diameter line (Hi Side) of your aluminum manifold on the linseed. The insert does not get installed in the compressor, but goes in the hi side of the manifold.
If you are retaining your stock AC line set, suggest you contact Glenn at Highway Stars . Give him a call and he will set you straight.
Good Luck
Good Luck
