The A/C fuse and ECM SOL fuse have to be good.
Check for +12 on both sides of the low pressure switch light green and light blue wires to a good ground.
Then check the dark green wire out of the A/C relay to a good ground at the relay as well as at the A/C compressor.
Then check for a good ground on the black wire at the A/C compressor connector it is interrupted by a high pressure switch which opens the ground if too much pressure is in the system, wire is on the back of the A/C compressor I believe for that.
That connector must be in place for the compressor to come on.
ECM SOL 10amp is good, there is no juice on that dark green wire by the relay. Connector on the back of the compressor is connected. Still no juice at the compressor so the AC Comp. clutch will not kick on. Where is this other AC Fuse you are talking about? What AMP?
