Ac delco or fel-pro intake gasket?
SNAKE250R
My 86'gn started having some high blm #'s so i'm going to start by re-sealing my intake manifold along with new vacuum lines.i have a stock intake but i am unsure on whose intake gasket to use fel-pro or ac delco? Part #?
Felpro works fine, you can get the part number at autozone.com
Intake Manifold Set:Fel-Pro #MS 96033. I usually pick them up O'Reilly's
Yeah, I second the Napa one, I've installed two with great success, but it seems to me like you can't go wrong with whatever u choose.
i called my local napa,they no longer carry the victor reinze.autozone sells three different part #'s fel-pro ms96033pb valley pan $26.99 , #1200 performance,(1.10x2.05 port size)no cross over $19.99 or #1201 performance, (1.32x2.35 port size) $23.99.does any one recommend the ac delco?
I like VR or Delco. I can get VR up in Canada? Got one 2 months ago? 1 day order?
Some (VERY FEW!) have said the Felpro can have issues with bolt hole alignment but I heard that like 2 times in many years. I used one without issue one time?
You dont want the 1200 series as they dont have a valley pan from what I understand? Could be wrong??
Thanks for the info.your right ,fel-pro 1200 series does not have the valley pan.i'll try and find the vr gasket,sounds like the best of the bunch.why would you use a non-valley pan gasket on an intercooled motor such as the fel-pro 1200 series?
You want a valley pan. The 1200s have larger ports than stock so some people use these and cut the stock gasket to just use the valley pan portion. Someone also makes just a valley pan than can be used in conjuction with the 1200s .
