AC drain hole location?
I'm having an issue where when the AC is on for awhile water is leaking in the main wiring harness on the pass side of car. Where are the drain holes to clean out in the AC area? In the blower motor? I remember where someone was discussing this?
look up between the engine and heater box.. if you get just the right angle, you will see a slot about 1/2" tall and 2" wide with a rubber flapper on it towards the bottom of the fiberglass HVAC box. that is the drain.. figure out a way to get a screwdriver or something up there to clean it out as good as you can, then get up there with a garden hose to clean it out.. once you get all the gunk out of it, you will be able to set a garden hose on the cowl and it will just run right thru without flooding anything..
