The other day I was trying to see where to hook up the engine torque strap and I had my hand on the hoses where the go across the radiator and join the metal lines I heard something hissing as I leaned over into the engine compartment . I raised up and the hissing stopped ... Figured it had to be the AC so I got down close and sure enough if I press on the hoses they leak where the hose is crimped to the metal lines.
Thing is they appear to be a loose fit not a true crimped end.
Is this normal ? At least I know why I had to recharge the AC after rolling the compressor out of the way when I pulled the engine and could never find a leak afterward! AC has not been leakIng in normal use fwiw.
