ACCEPTABLE OIL PRESSURE RANGE.
RED LS1
SENIOR MEMBER
We built my pump and it turned out a little tight. I'm probably going to pull the thrust plate out because the housing was in great shape anyway.
I'm reading 75-80 psi at cold start up. The warmed up range sits at 40 psi at idle and about 65-68 at opened throttle.
Nothing really smoking anywhere that I can see. I have been into the throttle about 15 times and it's running great.
I was thinking i'd like to see 30psi/idle and 60/65 open throttle? How does that sound?
