Actual ECM Source Code
bruce
Rest In Peace
If you go here, and look under the file Source Code, you'll find reference to a 58.asm
www.moates.net/fileman/
If you run it thru an assemblier, it will assemble into a valid 58.bin.
For the new guys, this has nothing to do with .ecu type files and editing, this is working with the whole code in it's full form. This is the machine code translated into english.
It's an early version, and not well commented, I have to clean up my later stuff before I post that for public distribution. This will be available at other sites.
It's with this that you can custom taylor the code to do about anything you want. The original .bin was for a 27128 prom, so with some simple changes it'll fit in a 27156 prom and leave lots of room for modifing it.
And please follow the header instructions. While I'm sure some low life will want to make a buck off of this, my intent is for it to be used, in an educational way. If you want to cheat and steal, just remember what goes around comes around.
For those that are here to learn, and have fun, please use this to your heart's content.
