This question is for those who burn there own chips.  When adding timing to a chip what table parameters do you mainly modify in the spark table?  With the T6Tuner, do you typically scroll to the 255 mark and bump up the timing from 2000 rpm's and on?  I would like to modify my 100 chip to a 110.  Current spark timing tables from 2300rpm's @255 are 22 degrees.  Can I just change these to 25 with the addition of good gas?  Any extra info is appreciated.
M. Banas
87GN
			M. Banas
87GN
