you guys are bouncing around but still not there ...
now another fly in the mix the surge
its pretty much a given pump will come on at about 6psi (2.0v) and when pump comes on it isnt a smooth flow ..the pump has three valves and basically three chambers with a triangular diaphragm plate that gets stiff from the meth exposure .. they can and do create a pulse ..that pressure can show 0 (theres still alky spray at 0) then the the pulse can be over 50psi between one good valve and one that hasnt seated yet ..with time iit will eventually smooth out as the valves in the pump head flexes and conforms to the seat, i see this surge every time i start a pump and sometimes it can take up to a minute at full flow to clear up the surge ..longer in cold weather .
.imop this test should be done before every race as most cars sit and can watch your alky press logs on the first pass be choppy and then smooth out by the end of the run and then be just fine on the next pass .. you can do this test with razors alky tester
a simple way to stop the surge (well not stop it but get past it ) is take the hose off nozzle put it in bucket and turn the key on and connect a jumper from the map 5v(grey pin A ) to the map out (green pin C) and run the pump for a minute to work the valves in
now on the gain knob ..
when you boost the area that needed most adjustment was the transition at 15psi boost where alky needed to come in harder because most chips were done at that point so you have a gain knob to tweak that area in
if you set map sensor simulator in test kit set at 15psi and change the gain dial from 5 to 8 you can see in an increase pressure at nozzle as much as 30 psi and thats where having the knob full can hurt spoolup because of too much alky is coming in at low rpm vs the amount of fuel needed that AF goes fat and car feels flat ..dial it back and you can raise the af to where car is responsive
now you have knob at 5 and the alky pressure is around 75psi at 15psi boost and the spool is good ..the alky will progressively increase with map pressure but i assure you that at around 22 psi the alky pressure will just about reach max pressure and you can increase the map to 30psi and dial the gain knob up and down and will see very little change in the max alky pressure you had at 22psi
like i said get the tester from razor .. adjust the map simulator in the kit and play with the gain and youll see what i mean .
you can also use the tester to help dial in the boost vs pressure curve on launch using the dials inside the pac box and then see your results in your log
Thank you so much for this response!!
Just so I am clear in my understanding, you are saying that
regardless if I have the alky gain knob at 5 or 8psi, once the map pressure is around 22psi the alky system will have reached max pressure?
Once the system reaches max pressure, that will be the largest volume of alky the system will provide, unless we change the nozzle size to allow for an increase in flow?
Since the alky system will reach max flow at roughly 22psi, regardless of whether the gain knob is set to 5 or 8, when tuning the car you want to adjust the gain knob so that when the alky system
does hit max flow it does not cause a surge and cause a "fat spot" on the AFR table? So we would set the gain knob at whatever the car likes so that there is no "fat spot" when max pressure from the alky system is reached? And basically
regardless of whether we have the system at 5 or 8 on the gain knob, the alky system will ultimately have the same max flow? Is that correct? The gain knob is there more to adjust the alky flow at around 15psi to smooth the transition in the AFR table for when the alky is now at max flow?
But regardless of what we set the dial to, once we reach about 22psi, the alky pump will flow the MAX that it is capable of, whether we have the gain knob set to 4, or 5, or 8?
Am I correct in understanding that basically the gain knob is more for tuning the amount of alky at around 15psi?
Depending where the gain knobs inside the black box are set, (which control the rate of ramp and what psi the system will start to turn on at) which ultimately determine what psi and how fast the alky system reaches the max flow, once the "max flow" psi is reached which is typically 15psi from what you are saying, and the gain knob is used to lower or raise the amount of alky that is flowing into the engine at this 15psi area?
But the alky system will increase the flow of alky into the engine as the map pressure increases? Although REGARDLESS of what the setting on the gain dial is set at, the alky system reaches MAX flow that is possible for the alky pump at about 22psi?
Or were you saying that the alky will progressively increase with the map pressure, and that effectively stops increasing because it is maxed out when the map pressure reaches about 22psi, but that the FLOW of the alky system when it reaches the 22psi depends on what the gain dial is set to? So at 22psi with a gain knob set to 5, it will reach what the max flow of 5 can be, once 22psi is reached? With the gain knob set to 8, it will reach the max of what the alky pump can flow for the setting of 8 when the map pressure is about 22psi?
Sorry for all the questions.. I just want to make sure I understand this correctly.
I will be ordering the tester from Julio next week. I definitely would like to see these things for myself so I have a better understanding of all this.
Thank you for your help!
-Tyler
